Injector question
Old 05-05-2006 | 01:51 PM
lt4 fd's Avatar
Injector question
I have a set of injectors that sat for a few years on an assembled motor in my garage, now they are not working. Did they just get gummed up from old gasoline or what? How long should a used injector be able to sit and still work properly???
Old 05-05-2006 | 03:14 PM
TraceZ's Avatar
Re: Injector question
Try soaking them in a dish of carb cleaner for a few days.
I had the same problem once with a TBI injector... the car sat so long the injector wouldnt spray anymore. It got gummed up. Soaking it overnight in carb cleaner fixed it. The car ran fine afterwards, no problems.
You've got nothing to lose, right? Give it a shot.
Old 05-05-2006 | 08:36 PM
OBE1 95Z28's Avatar
I wouldn't trust running those injectors; running just one cylinder lean can destroy an engine. You can send the injectors out to be cleaned.
Old 05-05-2006 | 09:21 PM
TraceZ's Avatar
Good point, better send them out and get them cleaned and tested
Old 05-05-2006 | 11:48 PM
lt4 fd's Avatar
Would 3 months be too long to have let them sit? Im not too hot on the idea of paying a lot of money to have stockers cleaned when I can pick up a used set for way less or an aftermarket set used for the price of cleaned stockers ya know? Im wanting to buy another stock set to test and see if the injectors are causing my problem and the set im about to buy has been sitting about 3 months, would they more than likely be ok?
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
LT14LIFE
02-09-2015 09:35 PM
nophix
11-30-2014 10:26 PM
07-04-2005 05:00 PM
Quick Reply: Injector question
