Just click, no start
Old 04-11-2004 | 06:21 AM
ToocoolZ28's Avatar
I tried to start my 95 Z28 tonite and just got a click from the starter, It started fine the day before. I kept trying it and each time I got a solid click from the starter, eventually it did start after about 10 tries. So it sounds like I have power to the solenoid. Does it sound like the starter itself?
Thanks. Ron
Old 04-11-2004 | 06:34 AM
Cmr0z28's Avatar
I doubt the starter is bad. Probably either a dead battery or solenoid.
Old 04-11-2004 | 06:55 AM
magman's Avatar
typical dead battery syndrom
Old 04-11-2004 | 06:59 AM
pearlpurple's Avatar
Probably a dead battery, charge the battery and take it a local Autozone/Advance and have them check it out to see if your alternator/battery are OK.
Old 04-11-2004 | 09:08 AM
95GRNZ's Avatar
Thumbs up
Before you go buying a new battery, check your battery terminals. You might just have a loose or corroded connection.
TS
Old 04-11-2004 | 10:10 AM
FastZinTennessee's Avatar
Same thing happened to me. I replaced the battery with an Optima Red Top and it still clicks sometimes but will start after a few tries. The problem is probably in your starter solenoid.
Now this is assuming that you have good charge on the battery and when you hit the "start" position you get one "click" and then nothing, but if you keep trying eventually it will crank.
Old 04-11-2004 | 10:27 AM
teke184's Avatar
and check all the connections on the starter, a bad ground will prevent proper function.
Old 07-25-2024 | 09:41 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Re: Just click, no start
If you want to test the condition of the starter, have someone with a hammer under the car by the starter, have someone in the cab turn the key to try to start the vehicle, when the clicking starts, have the person under the vehicle start hitting the starter, if the vehicle now starts, you have a bad starter bendix.
Old 07-25-2024 | 03:50 PM
95LT4Z28's Avatar
had a similar problem with my 95. turned out to be loose / corroded connections in that block that's on top of the passenger fender well. cleaned them up and double nutted it . did not have the problem again
Old 07-25-2024 | 06:02 PM
Why are we raising 20+ year old threads from the dead???? What is the purpose?
ADMIN
DirtyDaveW
12-01-2016 05:37 PM
HuJass
08-29-2002 02:30 AM
HuJass
08-27-2002 09:58 PM
HuJass
08-27-2002 09:53 PM
HuJass
06-27-2002 11:04 PM
Quick Reply: Just click, no start
