keep blowing turn signal fuse
Old 08-12-2019 | 11:26 PM
95LT4Z28's Avatar
the last time 2 times i had the car out i blew the fuse for the turn signals. Where do i start looking?
Old 08-13-2019 | 08:36 AM
Re: keep blowing turn signal fuse
Do you know which action caused the fuse to blow - a left turn, a right turn, etc?
Did the circuit have the correct 15-amp fuse?
Fuse #2 also serves the backup lights. Is it possible the fuse blew when you put it in reverse?
Old 08-13-2019 | 09:39 AM
95LT4Z28's Avatar
Thanks Fred. i did have a 15 amp fuse. do not know what action caused it to blow. when i got back home i changed the fuse and the signals worked without blowing the fuse. its possible that it blew when i went into reverse. ill check it out. thanks
Old 08-13-2019 | 10:06 AM
While the turn signals are working, take a walk around the car and make sure each bulb is functioning properly. If it's not the BU lights, and the fuse blows again, a non-working bulb may be a clue to the problem area.
The wiring diagrams for the turn signals are fairly complicated. Shoebox has the main diagram and the BU lights, but I don't see the the continuations of the circuits that are on other pages.
1995 4th Gen F-Body Exterior Lights
http://shbox.com/1/back_up_lights.jpg
The download version of the 1995 factory service manual from GaryDoug is missing a lot of pages in the electrical diagnosis section, including the ones we would need. We would have to use the diagrams in the 1994 manual to try and trace things down.
Old 08-13-2019 | 10:09 AM
95LT4Z28's Avatar
just checked it out. replaced the fuse , turn signals working. fuse blows as soon as i put it in reverse . i replaced the switch in the trans 2 years ago cause i had no back up lights. working fine since then up until now. switch went bad ?
Old 08-13-2019 | 04:28 PM
peterpar's Avatar
Originally Posted by 95LT4Z28
switch went bad ?
Possibly, I would also check the back up light sockets for corrosion or water.
Old 08-14-2019 | 03:43 PM
95LT4Z28's Avatar
i checked the sockets they were ok. got the car up and pulled the plug off the switch. stuck a paper clip in the plug to jump it out. signals and back up lights work without blowing the fuse. changed the switch and problem resolved. thanks guys
Old 08-14-2019 | 07:16 PM
1 - glad you figured it out.
2 - thanks for closing out the thread. Not everyone does that.
6SpdLT1Z
04-19-2007 04:25 PM
Cwynn
06-29-2004 12:58 AM
ZYALATER
04-02-2003 10:47 PM
Z28 Tweaker
02-20-2003 07:26 AM
T/A Punk
08-13-2002 11:14 PM
Quick Reply: keep blowing turn signal fuse
