left turn signal/Blinker not working ???
ok so my left blinker isnt working
symptoms , when i hit the left turn signal it doesnt blink it just stays on rear light is solid front light = not turning on how ever the right side blinker works fine , i tryed switching out the rear blinker lights , that didnt fix it , also if i throw on the hazards both sides blink just fine ,
also from time to time when im driveing i notice the left blinker arrow on my dash will blink
Re: left turn signal/Blinker not working ???
The same thing happened to my car, but it was the right front turn signal. I replaced the bulb and everything was back to normal.
Just go underneath the car and remove the splash panel (held on by about eight 10mm bolts) and you'll see the back of the turn signal. You'll turn the bulb about 1/4 turn and it'll pop right out.
The only place to start is to gain ascces to the bulb socket and test it. If it;s 2 wire it should have ground on one wire and then the blinking hot on the other, If it;s 3 wire should have ground, constent hot when the lights are on and then a blinking hot with the signals. I ahve dealt with a lot of non blinking left front signals where the bulb is just not getting the hot feed. And everytime it turns out to be the DRL module. You have blibking hot going in but nothing coming out...
I'm guessing just a bad bulb in the left front where the turn signal element is broken and occasionally touching the daytime running light element. This would explain the non-functioning turn signal and the occasional turn indicator flashing. Just a guess.
if you want you can do a real fast test to ruel out or condem the DRL module. Remove the radio, the module is right behind it. Pull it out and unplug it. take a small peice of wire and stick it in the connector jumping the light blue/white wire with the light blue wire. This in effect is bypassing the signal going through the DRL module. Now see if the blinker works on the left front. takes all of 5 minutes.
http://shbox.com/1/flashers.jpg
Since everyone else has two cents in, here's mine. Although this shematic is for a 95Z, I feel fairly confident that yours would still be located similarly in this area.
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
teedoff59
08-08-2002 01:36 AM
