little question
Old 03-21-2007 | 05:06 PM
streetracerx's Avatar
little question
so it was around 40 degrees out and i had been gentle with my car the whole way. I went to mcdonalds and sat in the drive thru for maybe 5 minutes and in that time the engine heated up enough to turn the fans on at 220 degrees..is this normal, i mean it usually always does in the summer in the drive thru, but when its only 40 degrees out?
Old 03-21-2007 | 05:16 PM
2000GTP's Avatar
Doesn't sound like an issue, as long as it didn't peg in the red and the cooling fans kicked on, it sounds normal.
Old 03-21-2007 | 05:23 PM
ya, i have a 160 tstat i will be putting in in the next week or so, will that help keep the temp down a little so the fans dont come on as often?
Old 03-21-2007 | 05:28 PM
2000GTP's Avatar
It will probably have little effect until you get your PCM tuned to adjust the fan on/off speeds. Then your car will be running alot cooler.
Old 03-21-2007 | 05:34 PM
haha it just so happens i just ordered a tune from the new tuner guys at trifecta performance to have the fans come on sooner. nice
Old 03-21-2007 | 06:16 PM
2000slp2768's Avatar
doesnt sound like a problem. If it happened well you were driving I might be worried. but when you are stationary you dont have any air flow thorugh the radiator so the fans will come on, even at that low of an outside temp.
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
30thZ4C
Wheels and Tires
01-29-2015 06:03 PM
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
Hurin
12-13-2014 07:38 PM
Quick Reply: little question
