lowered 4th gens
Old 04-29-2005 | 12:18 PM
Jakeav11's Avatar
lowered 4th gens
how low is your ride...post pics
Old 04-29-2005 | 02:56 PM
Compstall's Avatar
Re: lowered 4th gens
I can barely fit two fingers between the top of the tire and the fender.
Old 04-29-2005 | 07:59 PM
n2oblkz
Guest
Posts: n/a
Pics of mine are in my sig below. They are DMS springs and are lowered about 1 1/4 to 1 1/2.
Old 04-29-2005 | 09:17 PM
JaysGone's Avatar
I cut my stock springs and have for years with no ill effects. 27 inches all around
Old 04-29-2005 | 09:32 PM
musclecar's Avatar
I put Intrax springs in mine and it seems to be on the bump stops in the front...lol I rides ROUGH!! Looks cool tho!!
Old 04-30-2005 | 11:51 AM
carlos64030's Avatar
There should be some pictures of the ride height of my car in my sig.
Old 04-30-2005 | 08:24 PM
Bayer-Z28's Avatar
I heard Intrax were awesome springs.. How low did you go? I'm looking at a 1" drop w/ the 17" SS wheels, same ride height from a stock 16" Z28 wheel..
I've also heard that the BMR springs suck......??
Old 05-01-2005 | 10:23 PM
musclecar's Avatar
It really didn't measure that much with a tape, but then again I don't know how much travel these cars have. I was told the springs were 2-2.5 but installed are more like 3. I have 18's on my car and wanted to close up the gap in the wheel well so I figured I would try them out!!
Old 05-02-2005 | 09:49 PM
will62085's Avatar
with bigger wheels, you buy a thinner sidewall tire...and end up at the same ride height...my freind had the bmr springs, and i really liked the way those rode, i think it was a 1.5 inch drop
Old 05-03-2005 | 12:10 AM
Compstall's Avatar
FYI, my 17" TT2's w/ 275/40/17 tires actually sit ~1" shorter in diameter than my factory wheels w/ 255/50/16's on them.
Old 05-03-2005 | 03:09 AM
DrivinSidewayz's Avatar
your factory tires were supposed to be 245/50/16, not 255
when you calculate tire diameter between 275/40/17 and 245/50/16, it comes out to less than 1/10th of an inch. (in a perfect world)
Old 05-03-2005 | 05:05 AM
Compstall's Avatar
I know what size they came with, I was just pointing that out.
Old 05-03-2005 | 12:01 PM
FastrDamnit!'s Avatar
riding on Sprint Springs 1.75" lower in front 1.5" lower in rear on SS (ZR1 wheel/tires). Looks great but very rough on bumps.
Old 05-03-2005 | 01:29 PM
nfa's Avatar
nfa
1 coil cut from the front stock springs, 3/4 coil cut from the rear with isolator removed and heat hose on the top coil.
26" front height, 27.25 rear.
with st35mm swaybar, bilsteins, gw upper controls arms. it handles pretty good and the ride is far superior that stock.
-1.7 camber, 4.5 caster, 0 toe in.
TheGreenZ28
10-04-2020 11:29 AM
HectorM52
01-31-2015 07:29 PM
formula79
23
06-20-2002 01:42 PM
Quick Reply: lowered 4th gens
