LT Clearance
LT Clearance
Just wondering what an upgrade to LT headers will do to my ground clearance? I have a buddy with a 97 Mustang Cobra who put LT headers on and his ground clearance went to sh*t, so I am kinda concerned to put them on my 98 z. Any help would be appreciated. thanks
Re: LT Clearance
im sure it is pretty tuff for someone who knows jack... shorties are a waste on 00-02 cars because the stock manifolds flow prettty much the same... i think the gains are like 5rwhp
teke has an instal page on his cardomain check it out
Re: LT Clearance
here is the install guide
clearance shouldn't be too bad. the ypipe is usually what you lose the most clearance with. since most LT ypipes are 3" and they have to go under part of the frame.
but to date i've never scrapped my headers, ypipe (when i had it) or my true duals now.
and florida has alot of speed bumps and steep driveways.
Re: LT Clearance
On a stock ride height car, I think you should be ok. My friend has long tubes and a catted y-pipe on his 00 z28 and he hasn't dragged anything ever. If you do, you are most likely to catch the y-pipe before the headers.
Re: LT Clearance
i have midlength headers and mine's lowered and there is a little metal tab bolted to the frame next to the exhaust by the cat on the passenger side that hangs down 1" past the exhaust to let you know when you're scrapin and yea, lowered with midlengths scrapes every now and then so i wouldn't recommend lowering if you get LT
Re: LT Clearance
For most guys, Pacesetter LTs are the way to go. A lotta people go with "bigger" name brands, but may not know why. If it cost more, it must be better, right? That's not always the case...and when you buy Pacesetter you will give a little on the coating. If that worries you, you can always buy uncoated and have them coated by whoever ya want. But in general, I've heard about less issues with the Pacesetter LTs.
Re: LT Clearance
Originally Posted by theroad64
Pacesetter headers are an example of a product that started out very poorly and then got a LOT better..fitment,coating and the welds are MUCH better than they used to be.
