LT1 VATS removal
LT1 VATS removal
While I have the dash out of my car, I want to delete as much stuff as possible. The eventual plan is for my car to be a weekend racer and not a daily driver. I have already completed some weight reduction such as the removal of the rear seats, air bags, spare tire/jack, air pump and quite a few other things. I want to remove the entire VATS system since I already have an aftermarket alarm. The VATS has already been deleted out of the PCM by Brian over at PCMforless. What would I have to do to be able and delete all the wiring and boxes from behind the dash? If I could do this, it will make it possible to delete the bracket that held on the passenger air bag as well. I called Brian and had a short conversation with him concerning this, but my phone seems to hate me lately. He said something about having to wire up the starter and fuel pump? I have never heard of this. My car is a 95 Z28 LT1. Thanks for any and all help.
fuel pump is not effected by VATS
theft detterant relay(VATS starter kill relay) is controlled by the BCM on 95+ cars
it is the BCM that monitors the key resistor, and sends a signal to the PCM saying its ok to start
feel free to pull the BCM, but you will need to rewire the theft detterant relay, to start without the BCM and to keep the nuetral safety system operating
I am not sure what else the BCM controls on these cars, so remove at your own risk
What is this "completely different module" that controls the starter and fuel pump?
Since you have a 1995 (going by your screen name), you don't have a BCM. BCMs started in 1996.
Thank you shoebox, I was hoping you would provide some information. Where is this Theft Deterrent relay and how will I know what terminal is A1? Do I not have to do the resister mod to the wires under the steering column?
Just to make sure I have this correct: If I ground the yellow/black wire permanently and since I already have the PCM re-programmed, I can delete all the VATS wiring and boxes?
The TDR is to the right of the glove box, tucked under the lower edge of the dash. The hatch relay is next to it. It's the only yellow/black going into it. The other wires are yellow or purple and much bigger.
Together with the re-programming you had done and grounding this lead, you don't have to worry about bypassing the key pellet or keeping the VATS module. Just don't remove the TDR.
Re: LT1 VATS removal
No, the light won't go out, because the BCM (96-97) controls it. The BCM would have to see the correct resistance from the key pellet (or a resistor).
10-31-2016 11:09 AM
