LT4 Value Covers for 95 LT1 Trans Am
Guys,
From the reserach I have done it would appear the LT4 Value Covers from the Vette is a nice alternative to the stock LT1 Value Covers. I am looking to reduce the roller rocker noise and ensure I get absoutley no leaks.
Anyone happen to have the correct part number and the bolts part number too please.
Is there a better alternative maybe I don't know about?
Thanks in advance!
Jeff
Thanks in advance!
Jeff
Re: LT4 Value Covers for 95 LT1 Trans Am
Shoebox has the complete part # info on his excellent LT1/F-Body website. If you aren't familiar with it, bookmark it.
http://shbox.com/1/4th_gen_tech1.html
LT4 valve cover LH 12552321 discontinued
LT4 valve cover RH 12552322
LT4 valve cover gasket 10108625
LT4 valve cover gasket set
incl mounting stud grommets *not GM*
Felpro
VS50443R
LT4 valve cover mounting stud 10108674
LT4 valve cover mounting nut 10108675
LT4 valve cover mounting stud grommet 10108626
LT4 valve cover PCV grommet 10240678
LT4 valve cover oil cap 12555685
LT4 Corvette PCV/CCV vent hose
from throttle body to RH valve cover 12557604
Felpro
VS50443R
Thanks Fred that url is excellent and I will book mark for sure.
So if I understand correctly they have discontinued the LH value cover but not the RH? I am confused? Doesn't that defeat the purpose in wanting to buy the RH if you can't get the LH???
At the end of the day I am looking to replace my stock value covers with ones that are quieter and fit the 1.6 roller rockers.
Felpro
VS50443R
Felpro
VS50443R
10-31-2016 11:09 AM
07-04-2005 05:00 PM
