Metal pipe on front of water pump
Old 03-17-2007 | 08:17 PM
Dwaynez28's Avatar
Unhappy Metal pipe on front of water pump
Hello, I got a replacement non AC/Delco water pump a couple of months ago. Last night my son drove it and the metal elbow piece that is on the bottom left (facing car)-hose goes in the direction of the battery came out. A "parking lot mechanic" told him the "O" ring blew out. They used electrical tape to seal it. No one at AutoZone could say for sure if it had a "O" ring or what. Is it fixable or is it pressed in or does the whole pump needs replacing. Use a sealant to glue it in?? Thanks for any help. P.S I know i should have went AC/Delco now.
Old 03-17-2007 | 09:10 PM
DeuceGI's Avatar
I took a look at an old water pump in the garage and I'm almost certain all the pipes are pressed in. FWIW when my original pump went south I replaced it with a new pump from NAPA which was significantly cheaper than the GM pump. At this point the NAPA pump has been on the car longer than the OEM pump. HTH
Old 03-17-2007 | 09:44 PM
I have heard that happening with numerous reman pumps. The pipes are pressed in. When mine went out a long time ago, I went with a new GM (AC-Delco) pump.
Old 03-17-2007 | 10:20 PM
Dwaynez28's Avatar
Thanks for the replies--So no way to repair without replacing pump?? New 'O" ring or tape sealant, glue sealant?Its under warranty still, but my step-son is the installer and wont be able to replace it if necceasry till Thursday--thanks Dwayne
HectorM52
07-30-2017 11:46 AM
RUENUF
03-13-2016 03:39 PM
MattFick
02-15-2015 10:16 PM
94Z28LS1toLT1
01-15-2015 07:18 PM
Quick Reply: Metal pipe on front of water pump
