My cat is TOAST - GLOWING RED HOT
Old 03-14-2005 | 11:27 PM
joey93turbo's Avatar
Add another problem to the list! I've noticed this distinct smell since I bought the car but didn't know what it was. Tonight we went for a drive and noticed smoke rising from the center console at a stoplight. I get out and look and the whole catalytic converter is GLOWING. It's obviously plugged.
Now I'm wondering what I should do. How tough is it to pass emissions with a gutted cat? I live in Oregon. How much does a replacement cat cost? I'm not going to be keeping this car so I dont want to sink alot of money into it.
Also, what type of problems/symptoms could a plugged cat cause?
Old 03-14-2005 | 11:30 PM
Klypto's Avatar
Re: My cat is TOAST - GLOWING RED HOT
i think they have a 8 yr warranty on them....
cory
Old 03-14-2005 | 11:37 PM
What're you talking about?
Old 03-14-2005 | 11:43 PM
Klypto's Avatar
i think stock cats have 8 yr warranty even if the car has a 3 yr warranty on it..
cory
Old 03-14-2005 | 11:52 PM
Knowklew's Avatar
gut it.......plugged cat can be really bad in the long run
Old 03-15-2005 | 12:58 AM
Oh I see what you're saying. Well my car is a '93 so it's still not valid
What's the likeliness I'll be able to pass emissions with a gutted cat?
I also found this cat on ebay for $35 + shipping
http://cgi.ebay.com/ebaymotors/ws/eB...category=33629
Old 03-15-2005 | 11:48 AM
Zack's Avatar
you cant pass emissions at all with a gutted cat, unless its just an inspection
get a high flow cat. it will sound better too
Old 03-15-2005 | 12:47 PM
jasons93z's Avatar
Gutted cat wont pass emissions but it DOES sound better than a high flow cat.
Old 03-15-2005 | 12:57 PM
You really need to find out why the cat was "glowing". It may be plugged, but you also need to look for the possibility you have a serious misfire condition, and the air and fuel from the misfiring cylinder(s) is ending up on the cat, and releasing a huge amount of heat as it burns. Simply replacing the cat might lead to a repeat of the same problem.
Old 03-15-2005 | 02:57 PM
Funny you said that, becuase I believe that's exactly what's happening. When the car is running there's a very strong gas smell, and the car has a bad hesitation. Do you think it's possible the cat isn't plugged but this rich condition is causing it to get extremely hot? Is the cat bad now after reaching those temperatures?
Also, do our cats have an O2 sensor in them?
Old 03-15-2005 | 03:28 PM
If it gets hot enough from burning the misfired fuel and air, the heat will eventually melt the cat. That's why in the OBD-II cars they have a flashing SES light... to draw you attention to the fact that continued driving could melt the cat.
What year is your car? If its a 93, there are no after-cat O2 sensors. No 4th Gen has a sensor located in the cat.
Old 03-15-2005 | 03:33 PM
Do you think I could drive it 30 miles at freeway speeds (60mph+) out to our shop without any problems?
Old 03-15-2005 | 08:57 PM
Bayer-Z28's Avatar
Just for shats and giggles check the air filter. Sounds stupid but my firebird sucked up a leaf one day and it did the exact some thing. Hesitating and glowing cat. It cuts off the airflow and richens it up.
Old 03-15-2005 | 09:16 PM
Thanks for the tip, I did it and it's fine.
stangspank
11-13-2015 01:02 PM
Critter
07-07-2015 08:33 PM
Collector Car
12-17-2014 01:12 PM
12-01-2014 08:08 AM
Quick Reply: My cat is TOAST - GLOWING RED HOT
