My Rear Hatch won't open
For some reason my hatch won't open when I push the button on my remote or the button under the dash. I hear it releasing but when I try to pull it up, well, it doesn't go up. I removed my speaker box to see if maybe that was the problem but no luck. The only way I can open it is if I stand behind the car and push the button on the remote and time it just right to where when I hear it release I pull it up. I shouldn't have to do that everytime I want to open it and when I take it to the car wash they can't open it so I have to open it for them and that's just emberessing. Has anyone had this problem? How do you fix it?
Re: My Rear Hatch won't open
Okay, I think your saying when you pull on the hatch and hit the release button the hatch will open. If that's correct then its the spring that opens the hatch and can be replaced. Try this link http://installuniversity.com/install...sity/index.htm
That should do it. Goodluck
Guest
Posts: n/a
I always have to hit my remote 4 or 5 times to get it to fully release, especially when it's cold outside...one of these days I'll finally remember to get a spring and do this.
![Unhappy](https://www.camaroz28.com/forums/images/icons/icon9.gif)
It didn't work. I did it exactly the way it showed in the diagrams but it still doesn't open, it pops up a lot harder though. When I push the button to open it I hear it open but then it closes again right after it does it like half a second after it "opens". What else could it be?
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
I had the same problem when my hatch struts died. Just like you described, I would push the button and hear it release, but then it wouldn't open. I replaced the struts and now it works fine. Doesn't make sense, but it worked for me.
01-13-2015 09:52 PM
regular Joe
08-10-2002 07:15 PM
