Need to Do Brake Job, Help
'95 Z28 LT1 Abs, live in the seattle area where there are hills and rain. Brake Rotors are always 'Warping' on cars in this area!
1). So i need suggestion of good but not too crazy price parts, to help this brake job last longer and less warping.
2). Never done an ABS system what different i need to do?
Thanks!!!
Thanks!!!
Re: Need to Do Brake Job, Help
Your claim that brake rotors always warp where you live would seem to limit responders to those who live where you live. Never heard of that one before.
ABS bleeding can be complicated. Best thing to do is follow the factory manual.
https://www.mediafire.com/?40mfgeoe4ctti
You also need to consider the fact that there are only about a 1/2 dozen people left on this site that can help, and they aren’t here 24/7.
Go with a Raybestos, Wagner, or Bendix set of rotors and pads from Rock Auto.
Bleeding drain your MC fill with fresh fluid and with another person bleed the RR, then LR, RF, and finally the FR all while adding fresh fluid as needed approximately a qt plus or minus.
Also need to bleed the two bleeders on the motor pack, if you follow the factory procedure. Both before and after doing the four calipers. If there are any EBCM codes set, the motors in the motor pack need to be rehomed , either with something like a Tech-1 or 2 or following the alternative procedure.
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I got rotors, pads and fluid from Sam Strano. I believe the pads were Hawk, which seem to have a very good rep. For whatever it’s worth, he actually talked me out of buying some stuff I didn’t really need. He has a website as well.
its been coming down in bucket for the last few days my internet has been out too...
Thanks everyone!
any suggestions on the back brakes, they started squeaking, thought it was the front until i tried putting the e-brake on and it stopped squeaking. the rotor doesn't look too bad.
Thanks everyone!
IIRC the piston should go back to sit almost flush with the parking brake piece. Worst case, Mienkie (sp?) will rebuild calipers for about $100 a pair if they are really damaged.
