Need imediate help ASAP!!!!
Ok, im comin home tonight goin about 60-65 down I95, in my dads 95 ford t bird, since my camaro is in the shop, ad I feel a bang, and the ca shakes like I ran over something. Then when I hit the gas, the throttle does nothing. Then the engine dies, And wont turn over when I go to restart it.
Re: Need imediate help ASAP!!!!
Did it blow any smoke?
Is it leaking any oil?
does the starter try to work?
is the battery good?
Is there any coolant in the oil or oil in the coolant?
Sounds very much like it threw a rod...any dents in oil pan from inside out? Is there water in the oil...milky? They will usually still turn over after throwing a rod and quite often even run but not always...if lack of oil pressure was the cause it might not. Just a guess from the limited info given.
Henson071
09-21-2015 04:31 PM
