Need Suggestions, A Little Stumped
Old 11-09-2019 | 01:40 AM
WhiteWS6's Avatar
I own a 1997 Trans Am with the LT1. Honestly I've had alot of problems with the car due to mistreatment over its life. Here's a precursor to my problem. The optispark died on me about five months ago so, I replaced the opti unit with a new AcDelco one, replaced the NGK plugs and put in some new MSD plug wires while I was at it since one was a little burnt up. The car has always had an O2 sensor light on, keep this in mind. The car ran great up until a week ago, it freely revs smoothly in neutral or with the clutch pushed in. However once I am in gear and moving it stutters and jerks quite a bit, progressively more the higher the gear. Once the car is warmed up it seems to not act up as much too. The motor is modified, it's a 383 with cam, heads etc. Would the O2 sensor explain this occurrence at all since the fueling from the computer may be different in neutral as compared to when I'm gear? I already swapped over the ICM since I read about it on another post. Or is it possible I killed another opti in only 300mi worth of driving? Thanks for the feedback
-WhiteWS6
Old 11-12-2019 | 10:11 AM
Re: Need Suggestions, A Little Stumped
What is the specific O2 sensor code...... there are 22 of them in OBD-2 for your car? Pre-cat O2 sensors affect how the engine runs, after-cat sensors not so much. Do you even have cats?
An O2 sensor code can prevent that bank of the engine from going into closed loop in the PCM, which might explain the difference between how it runs hot (closed loop) and cold (open loop for first 3 o 4 minutes).
Do you know the history of the car - like who tuned it?
Where did you find a new OEM AC Delco Opti? They stopped making them at least 5 years ago, switched to rebuilt units with a core charge for returning your old one. And even the rebuilt AC Delco units are getting hard to find. I saw someone recently who found an OEM unit collecting dust on the shelf at a GM dealer, but those finds are very rare.
Revving the engine in neutral withoiut any load on the engine is pretty much useless as a diagnostic. Your engine seems to run worse as engine load increases ("it stutters and jerks quite a bit, progressively more the higher the gear."). Increased engine load puts strain on the ignition system, but you seem to have replaced all the components. Yes, an Opti can go out in 300 miles... carbon tracking can contribute to increased misfires under load. A loose wire becomes a bigger problem. If the ignition system is healthy, then the fuel system becomes suspect. Another issue under load can be plugged cat(s). Hence the question above - do you even have them?
Old 11-12-2019 | 10:58 AM
WhiteWS6's Avatar
Thank you for responding, the car does not have any cats at all, the code it is throwing is for the pre cat O2 sensor on the drivers side, "O2 Sensor Circuit No Activity Detected Bank 1 Sensor 1", however it seems to come and go as it pleases, I've pulled it and cleaned everything aswell as tested voltage from O2 sensor and it tested good. I'm going to throw a new one in pretty soon but I'm limited by weather right now. The car is not tuned at all to my knowledge, planned to get a custom tune from lt1tuning right as the summer hits in Montana. However previously it had functioned without this issue even with the O2 sensor code on. I got the new unit from a friend that had bought it awhile ago but was still new in box. The jerking is better sometimes and worse others.
Thanks so much, WhiteWS6
Old 11-12-2019 | 11:34 AM
"Insufficient Activity" (P0134)..... or "No activity" (P????)? The code descriptions provided by some scanners are "generic" and not necessarily correct for the specific vehicle/engine. Shoebox's list is basically the list out of the factory service manual.
http://shbox.com/1/Dtcs.htm
You can download a free copy of the 1996 (same as 1997) factory service manual here - courtesy of GaryDoug:
http://www.mediafire.com/?40mfgeoe4ctti
Have you scanned recently for any new codes that may be hiding behind the SES light for the O2 sensor?
You can't really clean an O2 sensor. The exposed metal part with the slots or holes is just a shield. The sensor thimble it inside the shield.
What voltage did you check, and what did you use to check it? The PCM supplies an ~0.450 volt bias voltage. The sensor thimble adds or subtracts from that voltage based on comparing the oxygen level in the exhaust on the outside of the thimble to the oxygen level in ambient air on the inside of the thimble. The ambient air enters the thimble via the hole the wires pass through. If there is anything leaking on the outside of the sensor, like engine oil, or if it has been soaked with something like PB Blaster in order to break the threads loose, the thimble could be contaminated or the air may not be able to get to it.
A 383 ci engine, heads/cam, which probably has larger than stock injectors, is not going to run well with a stock tune. But you indicate this is only a recent problem, so it must have been tuned.
Old 11-12-2019 | 12:01 PM
WhiteWS6's Avatar
It is a P0134 Code, by cleaning I just meant the electrical connectors on both the harness side and O2 sensor side since I thought that may have been causing the code, I tested the voltage out of it from a video online with a torch and the end to see if the output voltage was close to 1 as it should have been. I have scanned it multiple times but that is the only code present.
Old 11-12-2019 | 08:34 PM
WhiteWS6's Avatar
Another thing that may help to understand the problem a little bit more is that the car jerks and stutters when driving normally with very mild acceleration, however when I accelerate from first gear at 100% throttle all the way to four it never stutters once. But if I am to fully accelerate from second it falls flat on its face and almost doesn't accelerate any faster at all.
Old 11-12-2019 | 11:47 PM
Manual or auto trans? What rear axle ratio?
Trying to accelerate hard at low RPM in the wrong gear (second, rather than first) actually puts more load on the ignition system than accelerating hard in first gear. What RPM are you cruising at when the problem occurs? Does it jerk and stutter with constant throttle position, or only when you try to accelerate? Do your hear any knock (detonation) when you try to accelerate at low RPM.
https://www.camaroz28.com/forums/lt1...nature-879835/
Old 11-13-2019 | 12:09 AM
WhiteWS6's Avatar
Manual Trans, 3:43 Gear Ratio, Cruising at about 1.5k or 2k rpm and the jerking is almost gone but still vividly noticable, it very lightly almost impossible to notice jerks when in constant throttle but jerks and stutters very hard when accelerating normally. Almost impossible to accelerate normally above 3k rpm. No I do not hear anything relating to detonation when accelerating at low rpm.
Thanks, WhiteWS6
marlar98
09-19-2015 07:53 AM
97pontta
01-02-2009 06:46 AM
dallas63
01-11-2007 10:10 PM
DMGroh
12-31-2006 06:26 PM
GrdLockV6
02-22-2005 05:17 AM
Quick Reply: Need Suggestions, A Little Stumped
