Need trailer hitch that will accomodate dual outlet exhaust.
Old 07-31-2005, 02:37 PM
  #31
94ConvertibleZ's Avatar
Re: Need trailer hitch that will accomodate dual outlet exhaust.
I have a Flowmaster set up with the stock chromed tips. I have a hitch on it that Uhaul installed. The only part of the hitch u see is the little receiver tube below the license plate. It's tough to see. I tow 2 jetskis and a Seadoo jetboat with no problems at all. I think the Z looks especially sweet with the top down and the skis hitched behind it . BTW, the 2 skis weigh about 1,000 pounds w/trailer and the boat about 1,200 w/ its trailer.
94ConvertibleZ is offline
Old 08-10-2005, 08:38 PM
  #32
StudyTime's Avatar
Well guys, the hitch arrived today. It'll be a while before I pull my boat with it, but nonetheless I have it in possesion. Hopefully, I'll be able to pull my boat with the hitch- without a hitch as total weight of the boat is ~1200 lbs, which is approximately 60% of the tow rating so this is an acceptable load. This conflicts with the previous weight I disclosed, but is more accurate.
I don't plan to pull the boat that often, only a few times a month during peak usage (summer) and will pull it less in the winter.
I'll post a link to pictures after I get some with the boat in tow.
Thanks to those who have followed this thread.
Ben T.
StudyTime is offline
Old 08-10-2005, 08:42 PM
  #33
Scream And Fly's Avatar
Cool, you won't have any problem towing. None at all. Actually, you'll barely feel the boat back there.
Scream And Fly is offline
Old 03-18-2007, 02:40 PM
  #34
IndyTruck's Avatar
Hey y'all --
I just put a Reese Shadowmount hitch on my kid's 96 Camaro so he can pull his 14' aluminum boat w/9.9hp outboard. Boat, motor and trailer combined probably weigh under 600 lb, so quityerbitchin!
I got the hitch at the junkyard off a car that had no exhaust, so while the price was right, I didn't know it wouldn't clear the Flowmaster that's on his car. See, the main frame of the hitch goes further to the drivers side than the passenger, because of the way the gas tank is offset. The pipes are evenly spaced under the car. The DS tailpipe hits the hitch hard. If I spaced them out further so the DS cleared the hitch, the PS would probably hit the spare tire well. If I just moved the DS pipe, they'd be lopsided.
I'm thinking I could notch the DS tailpipe to clear. It's a stock 3.8, so it's got more exhaust flow than it needs. Or I could change to a muffler with the outlets on the same side. Or a single exhaust. Or I could try a different hitch.
Any other experience with this? What hitch and what exhaust did you use?
thanks!
kevin
IndyTruck is offline
Old 03-18-2007, 03:39 PM
  #35
Dave89IROC's Avatar
holy old post batman!!
been a while since I saw a 1 1/2 year old post come back from the dead
Dave89IROC is offline
Old 03-18-2007, 03:52 PM
  #36
I'm surprised you'll have to modify anything to get it to work. I had a Borla exhaust on my Z28 and the Draw-Tite hitch I had fit nicely in there. I did have to lower the exhaust to get it in, but that's it. The car towed great though.
Old 03-18-2007, 07:33 PM
  #37
matLT1's Avatar
matLT1 is offline
Old 03-18-2007, 09:00 PM
  #38
IndyTruck's Avatar
If you don't see old posts come up, that means people don't search - they just ask the same old questions over and over....
Thanks for the input, Scream&Fly...
G-BODYT56
01-14-2022 11:14 PM
IndyZman
10-22-2015 02:17 PM
football4life
10-04-2015 07:48 AM
RX Speed Works
10-01-2015 10:19 PM
94ZinEdgewater
09-08-2015 09:55 PM
Quick Reply: Need trailer hitch that will accomodate dual outlet exhaust.
