No air movement thru dash vents
I have a 95 Z28 that isn't blowing air out of the dash vents. Air blows thru the defrost,and the floor vents. The air isn't hot, but will warm up. Any ideals on what I need to look into to get the air movement into the vents would be greatly appreciated. Blend door is operating. Thanks
Re: No air movement thru dash vents
No "ideals".... but a few "ideas".....
The air distribution is controlled by various flapper doors that are powered by engine vacuum. The ususal problem is a broken vacuum check valve near the engine.
Courtesy of Shoebox:
http://shbox.com/1/hvac_vacuum.jpg
http://shbox.com/1/vac_check_valve.jpg
If you notice in the diagram, only the flapper door that switches between heat and AC is powered by a cable, off the temperature ****. If you don't feel the air switching from hot to cold when you turn the temperature ****, it may be a problem with the cable.
Sounds like the check valve to me. I believe when there is no vacuum it'll default to the defrost and floor......Id say the check valve or one of the vacuum hoses is the culprit....The check valve is near the PCM on the passenger side engine bay
I had the same problem, but on the passenger side, there is a T shaped fitting with 3 hoses going to it, and mine was busted... I replaced with what looked to be the same thing at a autozone, and it worked.
But my cable is also screwed up, so I have no heat at the moment... And the perfect time to, right in the middle of winter.... And my compresser seals are shot, so I'm screwed in the summer to. Lol.
It would have been a good idea to do some testing before replacing anything (though, I know the valve is cheap). The next most common leak point is the hose to the vacuum tank.
I left mine blowing on the floor and now that's all it will do. When I turn the **** it just hisses like it's trying to change but can't. I'll have to check out those lines. It does get warm though.
As Rob/Shoebox noted, test before you assume. Check the line all the way from the manifold to the check valve, to the vacuum reservoir, and to the dash panel. If you have a hand vacuum pump, use it so see if you can pull a vacuum on the system. Could be a broken elbow, cracked hose, a connector that fell off, etc.
Finally got back on my vent issue. Checked all the vacuum lines going to the check valve. The hose going to the manifold from the check valve was broke in half. Thanks for all your help. Works great.
stockssn2o
05-25-2015 08:54 AM
95chwagon
01-13-2015 09:19 PM
07-04-2005 05:00 PM
Darth Xed
13
07-22-2002 12:45 PM
