No start
Old 12-27-2015 | 02:34 PM
Codey1989's Avatar
Angry No start
Hey guys I've been working on my 1994 z28 for about a week now and it's has me stumped when I parked the car it would try to die when I put my foot on the gas and the next day the car wouldn't start at allI checked the fuel pressure it's good I changed the fuel filter still no luck so I thought it was the icm or the coil both of them are new so then I changed the opti spark plugs and wires I checked the spark by arking the coil wire off the header it was a yellow spark don't know if this has to do with the headers being stainless or not now when the ignition is turned over it chugs at about 100 rpms and dies smells really rich any solutions to this problem
Old 12-27-2015 | 07:59 PM
Re: No start
What were the results of the fuel pressure test? At prime? .... 10 minutes after prime stopped? ....while cranking the engine?
Did you scan it for codes? There are codes for the IAC and Opti? Not all of those turn the SES light on.
What brand is the Opti?
Is the engine stock or modified? If modified, what has been done to it?
Old 12-27-2015 | 08:56 PM
Codey1989's Avatar
Re: No start
I tested it when it primed it was at 43 the car has headers magnaflow exhaust and a k and n cold air intake Would the iac cause the car to not staying running
Old 12-27-2015 | 08:57 PM
Codey1989's Avatar
Re: No start
The opti is from summit
Old 12-27-2015 | 08:58 PM
Codey1989's Avatar
Re: No start
I can't get the scanner to connect to the car
Old 12-27-2015 | 08:59 PM
Re: No start
What scanner are you using?
Old 12-27-2015 | 10:32 PM
Codey1989's Avatar
Re: No start
It's a Bosch scanner I believe it's the one my Oriellys has
Old 12-28-2015 | 07:16 AM
moparman's Avatar
Re: No start
There's a good chance, if you went to O'Reilly's, they're trying to hook an OBDII scan tool up to an OBDI car. They will not interchange. It's the same with any of the parts stores, unless you find one that kept their OBDI scan tool.
Old 12-28-2015 | 07:46 AM
Re: No start
Bosch make a combo OBD-1/OBD-2 scanner. Not sure about the Bosch, but many of these will not work with the LT1 12-pin ALDL connector, because they are looking for a 12V pin and there is none.
Use this:
https://www.camaroz28.com/forums/com...95-lt1-874306/
95z_28_camaro_4_Ivan
05-08-2015 09:56 AM
94Z28LS1toLT1
02-28-2015 08:33 PM
F(ast)-body
02-26-2003 09:05 AM
gh0st
09-01-2002 10:24 AM
CLEAR
08-13-2002 10:07 AM
Quick Reply: No start
