not using gaskets to seal water pump
Old 07-16-2007 | 07:03 AM
ZL1modified's Avatar
i used the Right Stuff to seal my water pump...
i would not normally do this however the auto stores in my area did not have any gaskets... and i have no patience...
should i replace with gaskets or should it be fine?
Old 07-16-2007 | 07:10 AM
sssalah's Avatar
Was in the same boat a couple of months ago when I needed the gaskets for the impy. Don't remember which brand sealant I used, but it's doing fine so far.
Old 07-16-2007 | 08:39 AM
scottso's Avatar
The Right Stuff here. It does specify it is OK for water pumps and you can place the item in service right away. I just didn't want to wait for gasket silicone to cure for 24 hours. I want to complete the job and find out what I did wrong right away
Old 07-16-2007 | 08:57 AM
You can always make a gasket out of a cereal box.
Old 07-16-2007 | 09:07 AM
scottso's Avatar
I wish I could see your face to determine if you are kidding or not...
Old 07-16-2007 | 09:09 AM
u serious Shoebox?
wouldn't it eventually wick the water and create a class 1 or 2 leak?
Old 07-16-2007 | 01:22 PM
Z28SORR's Avatar
No he's not kidding!! Thin cardboard like a cereal box has, is almost the exact thickness of the original "paper" water pump gaskets.
How many on here remember using your girl friends or wife nylons as an emergency fan belt??
Old 07-16-2007 | 01:35 PM
scottso's Avatar
Well, that's one way to get the nylons off. Were you busy cutting through 90% of your fan belt on Saturday night?
But don't cereal boxes have a wax coating? Freaks me out, the thought of all that disassembly/assembly and using a cereal box as a gasket.
Old 07-16-2007 | 02:35 PM
Dead serious. It is a bit shade tree, but works. A thin film of RTV on both sides will make it a bit better.
I am not advocating this for your normal situation, just if you are in a real bind for a gasket.
Old 07-16-2007 | 02:38 PM
mdacton's Avatar
I always keep some extra gasket paper.....just incase
HectorM52
07-30-2017 11:46 AM
Magenta_Hearts
03-29-2017 08:54 PM
10-31-2016 11:09 AM
Jazsun
12-29-2014 12:14 PM
Quick Reply: not using gaskets to seal water pump
