Not yo typical oil question
Old 08-15-2004 | 11:50 AM
LT1Squirrel's Avatar
since i have Mobil 1 in the tranny and the rear id figured next change i would go with it in the engine too....i planned on using 10W30, but then got to thinking, is it the same quality as 5W30, what i mean is, does it have the same following?
Old 08-15-2004 | 12:58 PM
unvc92camarors's Avatar
Re: Not yo typical oil question
i'm pretty sure it just means it's a little thicker for the hotter months (and is suited to be used in them more)
o, and btw, check your sig
Old 08-15-2004 | 01:47 PM
i guess im not explaining this good ...i always noticed that everyone is on 5w30's nuts, but not many people talk about the 10w30 as much, physical differences aside, does the 10w30 have the same manufacturing process as the 5?...because at one point i remember reading that the 10 doesnt stack up to the 5's lubrication abilities
Old 08-15-2004 | 02:08 PM
ImportKILLER's Avatar
5W-30 will flow easier at lower temps than 10W-30 though 10W-30 doesn't shear as easily as 5W-30.
Either would work fine unless you are in extreme temp situations.
During the summer months, I usually will use a thicker 30w oil (GC) and during the winter, I'll go with a thin 5w-30 (M1).
Old 08-15-2004 | 04:00 PM
moparman's Avatar
Do a search for user "patman", and you'll find out more than you want to know about oil.
Old 08-15-2004 | 06:09 PM
10 seconds's Avatar
Thumbs up Re: Not yo typical oil question
When I went to all synthetic through out the drivetrain (power steering too) my car picked up approx. 2 tenths in the quarter mile. Can we say a best of 10.49 @ 129.83 so far on this 3900 lb. pump gas street car.
HectorM52
07-30-2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
10-22-2015 07:59 AM
NorthPoleDev
12-31-2014 03:20 PM
Queens94z28
12-20-2014 09:11 PM
07-04-2005 05:00 PM
Quick Reply: Not yo typical oil question
