Oil Pan Leak
Old 05-22-2005 | 08:26 PM
hashimsaleh's Avatar
Oil Pan Leak
I have an small oil leak drippen from right under my oil drain plug... now i tighten the blot and it seems fine and everything but it still leaks could it be a gasket or the oil pan cracked ?
Old 05-23-2005 | 09:47 AM
jeeves_83's Avatar
Re: Oil Pan Leak
At one time someone may have cross-threaded the plug and that may be causing a problem. You might add a small bead of silicone on the plug untill you figure out whats goin on with it
Old 05-24-2005 | 11:35 AM
Re: Oil Pan Leak
My oil pan is rusting out i think and its time to change it
any advice on this how i should go upon doing it
is it hard to replace is there an easy way to replace it or how ?//////
need help !!!
HectorM52
07-30-2017 11:46 AM
willismoons
05-27-2015 04:03 PM
SergheiS
04-26-2015 08:15 PM
DirtyDaveW
03-15-2015 07:01 PM
Queens94z28
12-20-2014 09:11 PM
Quick Reply: Oil Pan Leak
