Oil recommendations
Old 08-28-2006 | 10:39 AM
The Captain's Avatar
Oil recommendations
Ok all, I am planning on doing my first oil change on the Z28. Car has 27K miles on it, and I am not sure what type of oil I should put in there. I am thinking about putting synthetic in there, but am open to suggestions. Thanks!
Old 08-28-2006 | 10:43 AM
rlax31's Avatar
Re: Oil recommendations
The oil has been changed in the car before right!??
Mobil 1 syn is what I use
Old 08-28-2006 | 10:46 AM
lol yes its been changed before, this is just the first oil change that I have had to do to it.
Old 08-28-2006 | 11:14 AM
Coolformula's Avatar
GC German Castorl 0-30W...One of the best oils for lt1/ls1 cars.
Old 08-28-2006 | 11:20 AM
angel71rs's Avatar
If you can't find GC, M1 0w-40 synth is a good second choice.
Old 08-28-2006 | 11:26 AM
IXLR894Z28's Avatar
M1 5W-30 is all that goes in mine.
Old 08-28-2006 | 04:50 PM
brians96Z's Avatar
I use Pennzoil Platinum full syn in my LS1. I have used conventional oil in my third-gen every since I have owned it, which goes clear back to 99. I beleive synthetics are better, but in some cases, especially on a lightly stressed engine, it can be overkill. People will probably disagree, but I just simply can't complain about regular oil, when changed regularly.
Old 08-28-2006 | 09:45 PM
rpm4lalo's Avatar
5w30 castrol gtx
Old 08-29-2006 | 02:04 AM
mmmchickenboy's Avatar
Castrol has another Syntec that is as good or better than the rare GC. look on the front of the bottle, it will say it meets european specs, those words are in a yellow box on the front. afaik, this full syn is very commonly available at AZ, and probably other retailers.
Old 08-29-2006 | 09:20 AM
2000GTP's Avatar
I only use the Mobil 1 synthetic as well, but I hear constant good things about the Castrol oil.
Old 08-29-2006 | 09:33 AM
You dont' want to use GTX thats not syn....
Use some good syntechic. Royal purperl,amsoil,redline,GC etyc etc
jer4251
09-21-2020 09:42 PM
R@mpage
04-20-2015 10:02 AM
BigWil
03-29-2015 12:24 PM
jasonduaine
Exhaust System
03-20-2015 09:00 AM
carl.froehlich
03-13-2015 12:38 AM
Quick Reply: Oil recommendations
