Oil tube broke. Help!!!
Old 11-15-2008 | 10:07 AM
95z96jp02exp02h's Avatar
Question Oil tube broke. Help!!!
I was installing a set of headers on my 95z and when it came time to pull out the oil dip stick tube it broke off at the case. I was wondering if anyone has any ideals? Didn' want to drop oil pan but if this is the only way can someone give me some directions.
Old 11-15-2008 | 03:09 PM
Try threading a self-tapping screw into the part of the tube that is still in the block ("case").
Old 11-16-2008 | 04:41 AM
Thanks, I'll try that tomorrow.
Old 11-16-2008 | 08:21 AM
chevynutman's Avatar
threading something into it could work spray some pb blaster or wd40 to lube it or a flathead screwdriver to turn it other than that if it is too tight you will need to drop pan just watch the metal shavings in the tube
HectorM52
07-30-2017 11:46 AM
kallcium
V6 Tech
10-07-2015 03:39 PM
willismoons
05-27-2015 04:03 PM
SpeedJunkee
04-23-2015 09:51 AM
07-04-2005 05:00 PM
Quick Reply: Oil tube broke. Help!!!
