Power Door locks
Power Door locks
My drivers power window doesnt work and niether do my power door locks , My passenger side window works but the motor is definately going bad because it will roll down but rolls up slowly then you have to wait a minute to roll it up some more, I plan on replacing the window motors but what do I look at to find out about the power door locks? I already checked the power windows breaker in the interior fuse box, Do you think that the drivers window motor is completely shot or could it be something else that is also causing the locks to not function. Thanks Any help is appreciated
I did some work on my power locks to get them to work reliably. Depending on if you have remote entry or not the wiring varies a bit. But if both the drivers and passenger switches aren't installed the locks may not work from my experience. The best way to figure it out is to go to shoebox's web site and find the wiring diagram for the car. Then figure out which wire is incoming power to the driver's switch. Check it. If it is there then see if power comes out of the switch on the proper wire.
If you have keyless entry the control module could be shot which will cause all the locks to not work. Mine worked but I ended up replacing it so I could do a remote shaved door handle install.
Charlie.
Charlie.
