Power steering question
Old 03-12-2005 | 07:41 PM
94z4ME's Avatar
I cant figure out if my pass side fluid leak is oil or PS fluid. What would happen if I drained my PS fluid and let the engine run keeping my wheels straight maybe even off the ground. Would I damage the pump or anything? I figure this way I could rule out ps fluid or not.
Old 03-13-2005 | 01:00 PM
hotrod18_69's Avatar
Re: Power steering question
I wouldn't do that, you might burn the pump up. You can't tell by the color or smell of the fluid?
Old 03-13-2005 | 01:33 PM
You will smoke a pump without fluid. Don't do it.
Old 03-13-2005 | 04:48 PM
94z4ME's Avatar
The color is identical to my oil, since the oil is relatively fresh and still light brown.
Shoebox, what if I remove the serpentine belt and run the car off a battery charger?
Old 03-13-2005 | 06:19 PM
Bone Daddy's Avatar
Keep this simple.
Just take a drop on your index finger and thumb, and you should feel a texture difference between oil and psf. Not to mention the difference in smell.
You could always do a taste test.
Old 03-13-2005 | 07:44 PM
OBE1 95Z28's Avatar
Could also be a leak of the A/C system if your car is equipped with A/C. There's oil in the A/C system the the A/C compressor is located right under the P/S reservoir.
Old 03-13-2005 | 09:55 PM
The engine will run off the battery for a while, until the reserve capacity is used up.
HectorM52
07-30-2017 11:46 AM
Airplanedoc
02-01-2015 07:14 PM
Hurin
12-13-2014 07:38 PM
XtremeLt1
09-13-2002 08:50 PM
Quick Reply: Power steering question
