Power window issue
Old 01-28-2022 | 02:09 PM
Z28gr.mans's Avatar
Power window issue
Hello all, I have no power to either window. I have determined it’s not the fuse or breaker or the switches or the RAP module as I still have power to the radio and door locks.
The Driver side window got stuck halfway down when the regulator collided with an obstruction, which happened to be the down button for the DS switch that I shoved into the door skin while the panel was removed. But it started smelling like faint plastic burning before I got the switch out of the door.
Now neither window works and im pretty sure I melted a wire or a ground but I’m not quite sure where to go from here.
Old 01-28-2022 | 02:24 PM
Re: Power window issue
Could have damaged/melted the switch assembly as well. Check the power and ground connections on the driver side switch. Shoebox has the wiring diagram and a detail of the connector pins (94 should be the same):
http://shbox.com/1/pwr_window_schematic.jpg
http://shbox.com/1/window_motor_switches.jpg
The motor also has a thermal breaker built in (shown in the wiring diagram). That may have been damaged when the window jammed.
KYWes
02-27-2012 04:21 PM
95Z28LT1-PA
03-11-2010 11:09 PM
z28rp
01-13-2010 11:01 AM
Big_Z
02-19-2005 05:52 PM
bachehbad
03-15-2003 08:31 PM
Quick Reply: Power window issue
