Rattling door
Rattling door
Whenever my doors are closed harder than absolutely necessary, they make a rattling sort of sound. Most older cars ive seen do the same thing, but is there anything i can adjust to make them close like quieter? Thanks
Re: Rattling door
Same here. I'm willing to bet it is the window regulator - there's a lot of pivot points that get loose. Put the window in different positions and close the door - I'll bet it will either sound different or go away.
Re: Rattling door
Its mostlt because the doors are made of composite material and that in time the window regulator arms get loose a little and that's your noise. Mine dose the same thing, I'm use to it because of any of my other older cars did the same thing. You could take the panels off and try to adjust the actuator arms but be careful of master switch clips so you don't break anything. Good luck.
Aaront810
08-29-2020 09:34 PM
autoxr166
09-25-2015 04:21 PM
z28cam1993
09-09-2015 04:08 AM
