rear wheel speed censor
Old 11-30-2019 | 05:03 AM
peewee2012's Avatar
i have a 1996 z28 camaro. my service engine light keeps staying on. i need a new rear wheel speed censor for it but they are discontinued. does anyone know where i could get one. i have searched the internet. no such luck.
Old 11-30-2019 | 09:27 AM
Re: rear wheel speed censor
A problem with the rear wheel speed sensor would set a code in the module for ABS and traction control (if equipped with optional TCS). It would turn on the ABS INOP light, not the SES light. Or, is it possible you have the code (P0500-manual trans, P0502-auto trans) for the vehicle speed sensor (VSS)? The VSS is mounted on the transmission tailshaft housing.
If it actually is the rear wheel speed sensor, does your car have ABS only (one sensor on top of differential housing), or ABS+TCS (two sensors - one sensor on the backing plate at each end of the axle assembly)?
DAVE00
05-31-2009 09:27 PM
xstoyz
08-14-2008 07:37 PM
DMGroh
10-07-2006 11:32 PM
boosted-lt1
07-08-2006 08:16 PM
InjectedSS
06-15-2003 11:59 AM
Quick Reply: rear wheel speed censor
