Refueling issues?
Old 04-26-2014 | 09:56 PM
Orangejews's Avatar
Refueling issues?
My '95 Z refuses to normally take fuel into the tank filler neck. It will pump a few gallons if I'm low, then the pump thinks it's full and shuts off regardless of the angle I'm holding it at. I have to sit there and feather the handle on the pump nozzle so it doesn't trip the 'full' sensor. It's really annoying and I ended up overflowing the fuel tank once. It's like there's something partially blocking the fill neck. I really don't want to drop my tank.
Anyone had any similar issues?
1995 Z28
T56 Trans
ACT 6 puck Clutch/FW/PP
Comp Cam
Custom 3" mandrel Exhaust
DC High-Flow Cat
HAWKS short shifter
Old 04-29-2014 | 07:24 PM
crazyswede1027's Avatar
Re: Refueling issues?
My work truck had same issues was a blockage in filler neck. Might want to shine a flash light down hole see of you can see anything. Or try to remove neck and replace.
Sent from my iPhone using Tapatalk
Old 05-01-2014 | 10:55 AM
Orangejews's Avatar
I'll see if I can peer down in there and check it out. What was causing the blockage? I'm assuming someone stuffed something in there?
1995 Z28
T56 Trans
Comp Cam
DC High-Flow Cat
HAWKS short shifter
MyfateZ28
10-05-2015 12:36 PM
rocknroler69
04-29-2015 10:24 PM
sseeya
04-09-2015 06:38 AM
Alex Barnes
01-24-2015 10:21 PM
Chris Ja
09-04-2002 09:42 AM
Quick Reply: Refueling issues?
