removing wiper arms?
Old 03-26-2008 | 02:11 PM
blackbirdta's Avatar
after removing the nut on the wiper arm how do you get the arm off? thanks
Old 03-26-2008 | 03:02 PM
Should pull off, but you may need a 2-jaw puller if its corroded badly enough
Old 03-26-2008 | 03:52 PM
doesn't seem to be corroded...maybe I could try forcing it a little with a pry bar? I don't want to break anything though...would autozone or anyone rent a puller?
Old 03-26-2008 | 07:13 PM
95camaroinok's Avatar
spray a little wd on it and let it sit for a little bit then take a flathead and gently pry from the bottom while wiggling the crap out of it... It'll come off
Old 03-26-2008 | 09:02 PM
Oxygen454's Avatar
Try not to pry, I tried that a few years ago and cracked my front window. Not cool.
Old 03-26-2008 | 09:19 PM
there should be enough room to pry "lightly" between the arm and the stud it sits on.... should have clarified that more. Dont get too frustrated and crack your window.
also, the easier you work with it the easier it will come off, it is spring loaded so pulling or prying hard will just bind it up on the stud.
Old 03-27-2008 | 07:54 AM
01Z's Avatar
01Z
A special wiper arm pulling tool is sold in the HELP section at Advance. I think it was less than $10. I bought one, put it to work and promptly broke the **** off. Adjustable or clamping pliers will work in place of the ****. Pulling my wiper arm to replace a broken regulator (some call it a transmission) ranks among the hardest things I have had to do with my car. Corroded fine splines and the very slight taper almost make it a press.
Old 03-27-2008 | 07:09 PM
i'll try to pry it then. i have a spare arm off the car so maybe i can get a feel for it so i don't break anything.
btw...i took the spring off and it isn't possible to get back on without taking the whole thing off. i was playing with the spring to try and get more tension on the windshield, but it turns out it's not the spring at all, but the hinge on the arm it tight for some reason. swapping out these arms should work. thanks!
Old 03-27-2008 | 08:51 PM
smithtim's Avatar
if you are trying to pry it off be very carfull:
#1 keep the pry bar on metal ( i.e. edge of your hood if possible)
#2 either wiggle it left to right and/or spray with wd
Note if you force it off or pry on the actual glass you will crack your winsheild, have heard of a few people doing this... to avoid doing this try a puller instead of a prying but again make sure your point of force is on metal not glass
good luck
Tim
Old 03-28-2008 | 12:37 AM
Oxygen454's Avatar
Ya like I said, I cracked mine and I barely pushed at all. Apparently a few people I have met with camaro's have cracked there windows haha.
Old 03-28-2008 | 07:37 AM
WD-40 isn't the best penetrating oil in the world. Try some PB Blaster. Still seems to me that a simple puller would be a lot safer than prying things apart.
Old 03-29-2008 | 03:17 AM
Injuneer is the MAN. I dont know what I was thinkin with the WD on that post... I keep a can of pb around... Definately a better option... To the OP if your replacing the whole thing anyway, get a large set of vice grips on that thing and wiggle the s*it out of it.
Old 04-01-2008 | 08:59 PM
The $6 Man's Avatar
I pulled up while wiggling on the arm and hit the mounting stud (don't beat the $hit out of it) with a hammer. They finally worked loose.
Red Hawk 94
03-18-2019 04:03 PM
KYWes
05-22-2015 08:48 PM
canbaufo
05-05-2015 03:43 PM
R@mpage
04-20-2015 10:02 AM
stopthatman
02-09-2015 09:00 PM
Quick Reply: removing wiper arms?
