Security led help
#16
Re: Security led help
But you've been more than awesome Fred. Checked and brushed up all my grounds, have to wiring and fixed replace the hvac valve thing by the pcm (it cracked) and should be able to try to turn her over. Just praying it doesnt eat up this battery since Ive checked most of the wiring and fixed the corrosion in the underhood fuse box and she starts up. All new fuses, all new relays under hood, new fuel pump relay, relay behind radio on passanger side is good, relay behind inside fuse box is good, didnt get to check relay by bcm yet, all grounds under hood are clean and tight, (icm to frame, battery to frame and engine mount, pcm to firewall above starter) Am I missing anything?
