shave the heads or not?
#16
Re: shave the heads or not?
I beg to differ. Shaving or milling the head can be beneficial to increase the compression ratio. Depending how much you are willing to cut the head. If i were you on a near stock car, i would take .020 off the cylinder head, and find a good head gasket with a thin compressed thinkness so you get a good seal. Running a thinner head gasket will also bring the cylinder head closer to the piston. Which will depend on stock head gasket comp. thickness and aftermarket gaskets.
#17
#18
yes the ls1s were detuned i have made some really good numbers with mine & now im at 526hp & want more lol. like ive said in my othere posts i dont know much about these motors or what they r capable of doing but it sounds like there about maxed out from what ur saying. my other question is after i put the LTs on where does the o2 sensor go? do i need to wel in a bung in the rear by the collector where most of them are?
#19
#20
#21
#24
Well im sure that it wont make the SOTP dyno a night and day different, but it can definatly increase performance which depends on how much you mill the head, and the gasket choice. A cam swap would definatly complement the increase in compression. If you notice a majority of N/A high performance engines are high compression, normally 10:1 ratio if not more. Off the top of my head im not sure the comp ratio of the L98 (which im assuming is the 350) but like stated the heads dont flow very well, but if you plan on modding it in the future(cam, heads, etc.) it can definatly benefit you to mill the heads if you are removing them.
#25
#26
Putting lipstick on a pig is a waste. Cheaper to simply buy a used set of vortec heads.
#27
#29
I'm going to throw my hat in the ring for NOT shaving the heads. As mentioned, you usually have to shave the intake, depending on how much you take off. It can also slightly change the valve geometry. I personally prefer to get more compression by getting different heads or pistons.
One option is to get a used set of the aluminum "corvette" heads.
However if your thinking about doing upgrade in the future why not just put it back together for now and do some research on the L98, while your saving some money.
#30
OK SCRATCH EVERYTHING!! He just sent me a text & said theres no way he can do any of this. he just wants me to mill the heads if they need it & put it back 2gether! DAMN IT ANYWAY! ohh well i tried. thanks 4 all the input its been a good learning process. now if i can remember how it all goes back together hmmmmm
