Smoking into the cabin of the car from behind radio
Old 07-19-2024 | 11:22 AM
NizzyZ28's Avatar
It’s a LT1 95 Z28 Automatic but Not only the cabin but the engine bay and under the car about after 10 minutes of running and driving somewhat fast it’ll slowly build if not driving or window rolled down I’m only 21 and I’m trying to keep this car the guy I got it from a dad had passed and it had sat for like a year outside I believe I live in northwest so I don’t know the damage all the way really but it’s runs and drives good and the I’m able to still spin it out good with tremendous clouds but before I continue my foolery I’d love to fix it and it was doing this problem before I learned to spin the car. But I’ll drop pictures and videos.
File Type: mov
Old 07-19-2024 | 05:27 PM
Re: Smoking into the cabin of the car from behind radio
Any particular odor - sweet/coolant, burnt plastic/electronics, burnt engine oil, transmission fluid, etc.?
Is the oil level, or coolant level below normal? Have you replaced the oil, coolant and other fluids since taking possession of the car?
How many miles on the car?
Old 07-19-2024 | 05:34 PM
NizzyZ28's Avatar
about 160k miles on it I know it’s an fluid leaking I’ve done all the fluid changes about 3 weeks ago now but I know it’s somewhat sweet really don’t know the difference in the smells too much I know the under of the car is a oil leak supposedly as word from a mechanic I know. I fill the coolant reservoir and radiator up and then about after 15 minutes of driving I get the low coolant light but the fluid levels visually haven’t changed and I know the oil gage has been working right but so far only the tranny, coolant and oil change
Old 07-19-2024 | 06:32 PM
Coolant smells sweet when it burns, as in dripping on the exhaust system. There is a “steam pipe” at the rear of the engine that connects the heads and directs coolant and any vapor to the radiator. Might be the culprit.
http://shbox.com/1/oil_pressure_sensor.jpg
You need to check the coolant level in the radiator (not the reservoir) after driving for a while. It should always be up to the very top of the fill neck, with no air.
2010_5thgen
9
01-04-2010 07:19 AM
MustangEater82
10-22-2004 04:04 PM
OldSchoolSS
06-27-2004 12:12 AM
93 Indy
East South Central
19
09-21-2002 03:01 PM
91 Redd Sledd
Mountain
9
07-04-2002 10:07 AM
Quick Reply: Smoking into the cabin of the car from behind radio
