Steam Pipe Gaskets
Old 01-04-2024 | 01:39 PM
caci's Avatar
Steam Pipe Gaskets
'94 LT1
What are you using for the banjo-bolt gaskets? I bought a NOS assembly when I got my car back on the road a few months back.
I included the rubber-lined washers. However, I'm having to replace the engine and those washers appear to be singlle-use (off-center distorted).
They also appear to be unobtanium. Any suggestions? I'm leaning toward copper brake line washers.
They work on steel lines to alloy calipers and get MUCH hotter than this pipe will get, at a much higher pressure.
Chris
Old 01-04-2024 | 02:51 PM
RUDEDOG's Avatar
Re: Steam Pipe Gaskets
Dowty Seals. Not hard to find.
Old 01-05-2024 | 08:35 AM
caci's Avatar
Thanks. My mechanic has a version, for A/C - much smaller diameter rubber/metal, for given bolt size.
I found some assortments with wider rubber/OD, but still not the overall diameter of OEM. Gonna give these a try.
Chris
Jim Rockford
08-01-2009 12:55 PM
Jazsun
06-04-2008 11:50 PM
streetrod93
04-24-2007 05:50 AM
bluecmaro96
07-09-2003 04:01 AM
Transcam96
05-29-2003 12:14 AM
Quick Reply: Steam Pipe Gaskets
