steering shaft/ coupling shaft
Old 11-28-2019 | 09:26 PM
Misfits's Avatar
I have a 1997 camaro z28, 6spd. Im looking for the entire coupling steer shaft. GM part no 26020775, it is no longer carried by GM. I tried autozone and found no luck. My rag joint and bottom u-joint both have excessive play. Any input would be appreciated.
Old 11-30-2019 | 10:05 AM
DrewHMS97SS's Avatar
Re: steering shaft/ coupling shaft
If the U-joints are loose, I would either hunt down a unit in good condition from the junk yard, or possibly see if a drive line specialty shop can replace/repair them. For the rag joint, I would flat out replace it:
https://www.camaroz28.com/forums/sus...ide%2A-881963/
I myself installed the conversion kit from Unbalanced Engineering, and have been very happy with the change. Unbalanced Engineering GM Products
87Aerocoupe
09-13-2017 07:09 PM
LT4Camaro
01-18-2008 06:53 PM
EKO
12-14-2006 11:52 PM
sc1twntrbo
05-07-2006 03:35 PM
Blown 96 WS-6
08-24-2003 06:44 PM
Quick Reply: steering shaft/ coupling shaft
