Stock tire size on a 2000 Z28
Re: Stock tire size on a 2000 Z28
Unless the car was ordered with Z-rated tires (don't remember the RPO, code, but I'm usre somebody has it hande somwhere...), the stock tire size is 235/55-16.
Which, of course, has the same overall diameter than the optional 245/50-16 and 275/40-17.
TS
TS
The other size is for V6 models.
edit: When I ordered my 02, the Z rated RSA's were standard equip on all V8 cars, with GSC's being a $200 option. I had the tires in sig, so took the free one's.
PJ
PJ
TS
TS
The 235's were standard up untill 01 or 02 I think
if you had 235's you had the 120MPH speed limiter
245's were an option and most had them.
Look in your driver door sticker, it should say what tire your car came with.
Originally Posted by shoebox
The 235/55 and 245/50 are not the same overall diameter. The 235 is ~.5 in. taller.
I don't know what that means.
Originally Posted by SVT03
A plus size would be a 245/40/17 or 275/40/17 it has to be bigger than the original 245/50/16.
Just for the record, overall diameter of 245/40-17 is over 1" larger and is not considered as "plus one".
Actually, 275/40-17 is "plus one". It is 0.02" larger in diameter than the 245/50-16.
The 235/55/16 almost exclusively came on V6 cars. The 245/50/16 was the standard tire on the Z28 and was avialable in two speed ratings depending on the speedometer in the car. The 275/40/17 was only used on the 96-02 SS cars.
Originally Posted by RE AND CHERYL
Actually the 17" SS wheels are consittered a +1 because it refers to the rim and not the tires. If you do the math the 235/55/16 is 13mm taller than the 245/50/16 and about 10mm taller than the 275/40/17.
Who knows...
My son had a 95 v6 with the 235 tires. His freind had a stock 95 Z28 with the stock 245 tires. When I bought my 94 Z28 it still had 245 tires on it. Also, I beleive the salad shooters on the 235 and 245 tires were different widths.
Didn't find specs for a 2000 Z28, but here are specs for a 2001 from NADA's page.
Maybe somebody who has ordered their 2000 Z28 and maybe even has the original window sticker reads this thread and can confirm.
OK--I still have the stock rims and have not changed tire sizes....My 2k Z came W/ stock Z's @ 245/50 ZR-16. Also keep in mind as the aspect ratio changes, treadwidth/sidewall height, if the sidewall height changes it's only common sense to figure that the overall tire diameter has changed. Not by much, but it still changes. Mabie that will help.
Brandon Wittmer
12-20-2014 09:51 PM
Hurin
12-13-2014 07:38 PM
