Stripped bolt on positive side of battery. How to fix?
Old 03-05-2005 | 05:10 PM
stang_killa94's Avatar
The bolt that holds down the wire on the positive side of the battery somehow got stripped and now I have to move the battery around before i can start that car and sometimes it wont charge up because there is no connection. I tried just take the bolt out by twisting it but it just stays inside the red boot. Anyone know how to replace that bolt?
Old 03-05-2005 | 05:31 PM
Kataklysm's Avatar
Re: Stripped bolt on positive side of battery. How to fix?
As far as I know you need to get a new positive cable. Its a PIA to run it too.
Old 03-05-2005 | 06:41 PM
CMANZ28's Avatar
You can get a new bolt. When you wire an Amplifier into a car they make a special battery post. So if worst comes to worst you can use one the them.
Here is one on ebay for $1.99
http://cgi.ebay.com/ws/eBayISAPI.dll...755454358&rd=1
CmanZ28
Old 03-05-2005 | 07:02 PM
If it is the bolt, you can get replacements at any auto supply. If it is the battery threads that are stripped, you probably will have to replace the battery.
Old 03-05-2005 | 07:13 PM
Yeah its just the bolt that stripped, I guess my question should've been......How do I take out the old bolt? I tried to pull and screw but the bolt just spins inside.
Old 03-05-2005 | 11:43 PM
Mean Green Z28's Avatar
it'll come out if you tug at it long enough. You just have to pry it off the boot. I usually use pliers and press on the threaded side of the bolt and the edge of the boot and it pops right off. You'll get it
Old 03-05-2005 | 11:53 PM
Unscrew while pulling out.
HectorM52
07-30-2017 11:46 AM
maybe2fast
03-16-2015 09:45 AM
squarehead
11-21-2014 08:02 PM
07-04-2005 05:00 PM
MislMan
07-19-2002 11:41 AM
Quick Reply: Stripped bolt on positive side of battery. How to fix?
