Sucked in rad hose, 97 ss camaro
Old 07-22-2012 | 03:18 PM
shirleyk97's Avatar
Ok guys, i have a 1997 ss camaro that i replaced the waterpump on a while back, and now ive started having my bottom rad hose, passenger side, suck shut on me upon cool down process, ive changed the rad cap with one from work, ( Griffin Radiator ) and the hose thinking they could be faulty, NOT THE ANSWER! , ive inspected for blockage within the hose leading to the resrvoir as this can cause this type problem, no blocks, ive bled the system a million times, still sucks shut after driven and up to operating temps, any help would be great im pulling what hair i have left out over this one.
Old 07-22-2012 | 05:44 PM
Re: Sucked in rad hose, 97 ss camaro
Is it possible the rubber hose from the cap/neck to the reservoir is also collapsing under vacuum, preventing the coolant from flowing up the hose? The stock hose is fairly flexible.
It's obviously allowing coolant to flow out of the reservoir as it expands and heats up, but not flowing coolant back into the radiator as it cools down and contracts.
Old 07-25-2012 | 10:33 PM
Thread closed due to cross-posting.
Go here to see the current status:
https://www.camaroz28.com/forums/lt1...nstall-867647/
Jlo
02-03-2015 09:41 PM
pologreen97z
12-02-2014 10:42 AM
ro2207
12-01-2014 01:02 AM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
07-04-2005 05:00 PM
Quick Reply: Sucked in rad hose, 97 ss camaro
