Tach not reading correctly
Old 04-08-2024 | 12:28 PM
Z28Ray's Avatar
I have read somewhere that the factory tach does not always read correctly.
I hooked up a scan tool and the RPM is right around 800 at idle when warm which I believe should be about right but my dash tach reads 1100.
Is there a way to adjust the dash tach to read correctly?
Old 04-08-2024 | 10:18 PM
JakeRobb's Avatar
Super Moderator
Re: Tach not reading correctly
Are we talking about the ‘97 Z28 shown in your avatar?
Old 04-09-2024 | 05:48 AM
Z28Ray's Avatar
Yes
Old 04-16-2024 | 04:30 PM
Z28Ray's Avatar
Any suggestions on this issue?
Old 04-16-2024 | 05:30 PM
I’ve found them to be 100-200 RPM off. 300 RPM seems excessive. And 800 RPM is the stock program idle speed for the M6, engine warmed up (actually, 111°F and above).
Using your scan tool check PCM RPM vs tach RPM over a wide range of RPM. See if the error is a constant, a percentage, or random value. If it's a constant might be able to reset (move) the needle on the tach. Is there possibly an “overlay” on the cluster that required removing the instrument needles to install?
Old 04-16-2024 | 05:34 PM
Z28Ray's Avatar
Thanks Injuneer
I will look at that.
No overlay.
Car is completely stock.
Has only 27K kilometers on it (17K miles)
Old 04-16-2024 | 06:13 PM
White cluster overlays were all the fad back in the 90’s. Fortunately your low mileage 97 escaped unscathed……
Old 04-17-2024 | 12:02 PM
Originally Posted by TaylorCarter
Thank you so much for the suggestion.
IP Address 2409:4055:4e0f:5050:4d56:3b2a:e430:70d3 % Abuse contact for '2409:4000::/22' is ''
inet6num: 2409:4000::/22
netname: RELIANCEJIO-IN
descr: Reliance Jio Infocomm Limited
country: IN
org: ORG-RJIL1-AP
admin-c: RJIL1-AP
tech-c: RJIL1-AP
abuse-c: AR991-AP
status: ALLOCATED PORTABLE
remarks: --------------------------------------------------------
remarks: To report network abuse, please contact mnt-irt
remarks: For troubleshooting, please contact tech-c and admin-c
remarks: Report invalid contact via www.apnic.net/invalidcontact
Old 04-17-2024 | 12:08 PM
Z28Ray's Avatar
Was wondering what that was all about.
Old 04-17-2024 | 02:34 PM
They’ve opened maybe 50 fake accounts over the past few years. Almost all the IP addresses trace to India.
David94TA
9
01-06-2019 11:15 PM
merim123
08-07-2006 01:39 AM
Z-RATED94
05-02-2006 09:56 AM
wb3s94z28
05-04-2005 03:40 PM
ChrisUlrich
03-02-2005 01:13 PM
Quick Reply: Tach not reading correctly
