Taking apart an alternator?
Old 02-06-2005 | 10:40 AM
JeffsWorld's Avatar
Question Taking apart an alternator?
I am in the process of taking apart a used alternator to send the halves out to be powdercoated. I am then going to take the powdercoated halves and put the guts of a rebuilt upgraded alt (0 miles) into them. The problem with the rebuilt upgraded alt is that the case is cracked off at the mounting hole closest to the engine. My problem is is that I can't get the halves separated from the center section? I have removed all visible screws and the fan/pulley/electric connectors. I tried beating on the stator w/ a rubber mallet a few times and they won't budge? Am I missing something? Suggestions welcomed. Thanks. Jeff
Old 02-06-2005 | 12:50 PM
hazard2k's Avatar
Re: Taking apart an alternator?
Every alt i have taken apart are just pressed on to the center section. It might take some force, but it should just pull apart.
Old 02-07-2005 | 08:51 PM
Bayer-Z28's Avatar
Yes, they should just pull apart. Whyle you are in there, you could replace the brushes. If you didn't already know, when you reassemble the ALT push the brushes into place and use a paperclip to hold them in there until you get the halves back together .
Old 02-07-2005 | 10:11 PM
TraceZ's Avatar
I recently tore mine down to lubricate and clean it up. After removing the 4 case screws it came right apart. Getting the pulley nut off was the hardest part.
Old 02-07-2005 | 10:18 PM
Bayer-Z28's Avatar
Leather welding glove and an impact gun
Old 02-07-2005 | 11:07 PM
TraceZ's Avatar
I ended up puting it in gear with the belt on, wraping the belt in a rag, pinching it onto itself with a vice-grips and using a breaker bar on it. I'm sure your way would be easier.
DirtyDaveW
12-01-2016 05:37 PM
Red97LT1
03-01-2015 05:08 PM
Gtpguy
01-26-2015 04:50 PM
HectorM52
01-16-2015 10:21 AM
Darth Xed
07-01-2002 03:22 PM
Quick Reply: Taking apart an alternator?
