Is there an easy way to remove old gasket from throttle body?
Old 04-03-2011 | 02:12 PM
brian12's Avatar
I managed to get most of it off with an old credit card that has been sharpened but there is still a couple of pieces that wont budge. I have been spraying it with permatex gasket remover but it doesn't seem to be doing much. Is there something I can soak it in to remove it? What do the guys in shops who are on the clock do?
Old 04-03-2011 | 02:42 PM
chevy_dude97's Avatar
Re: Is there an easy way to remove old gasket from throttle body?
I used a scrubber brush and orange cleaner. In the shop I would use a adheasive removal wheel on a diag grinder. Then throw em into a parts cleaner. There where dudes who would tank carbs/tbs then media blast em but I found that after the media you where lucky to get them to seal for long.
Old 04-03-2011 | 03:00 PM
Southern Boys's Avatar
Exclamation Re: Is there an easy way to remove old gasket from throttle body?
I use a wire wheel and a cordless drill.. Or stainless steel and a cordless drill.. Get both at walmart.. Works fast..
Old 04-03-2011 | 03:16 PM
brian12's Avatar
Thanks for the tip.
Old 04-03-2011 | 03:36 PM
Marc 85Z28's Avatar
Razor blade.
HectorM52
07-30-2017 11:46 AM
Fatdog2
02-13-2015 08:19 PM
Queens94z28
12-20-2014 09:11 PM
thenewkid
11-27-2014 09:41 AM
07-04-2005 05:00 PM
Quick Reply: Is there an easy way to remove old gasket from throttle body?
