transmission fluid and filter change
Old 05-06-2015 | 11:24 PM
warmeck's Avatar
i am wondering if this will fit my 1994 camaro 6 speed and if there is a how to somewhere? ACDelco Transmission Fluid Filter TF289: Advance Auto Parts i know i need this and dexron 3 how many should i buy?
Old 05-07-2015 | 07:07 AM
moparman's Avatar
Re: transmission fluid and filter change
I don't think the 6 speed uses a filter.
Old 05-07-2015 | 07:19 AM
Correct. That filter is for an auto trans.
The Owner's Manual shows the capacity at 8 pints.
Old 05-07-2015 | 12:37 PM
Some of the pics are gone, but the basics are in this link at the bottom of the page.
Old 05-07-2015 | 02:09 PM
warmeck's Avatar
thanks shoebox
Old 08-24-2024 | 07:15 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
All your transmission needs (t56) is 90W dino oil.
Old 08-24-2024 | 08:05 PM
INCORRECT
Per the factory service manual, the Tremec T56 service manual, and the paper tag on the outside of my purchased new 94 T56, the T56 should be filled with GM Dexron II ATF. Later years required Dexron III, and that was confirmed by the paper tag on a T56 I bought from the original owner of a 1997. Using other fluids can lead to damage of the paper blocker rings.
http://shbox.com/1/t56_service_manual.pdf
https://www.tremec.com/faqs.php
Dansean1
06-09-2006 09:46 AM
CamaroGuy22
02-04-2004 07:36 AM
LWillmann
03-10-2003 11:44 AM
cdmelcher
01-11-2003 11:30 AM
bsmith
01-09-2003 07:07 AM
Quick Reply: transmission fluid and filter change
