Trouble Deleting VATS
Old 02-20-2005 | 07:30 AM
Valkyn71's Avatar
I recently had my security light come on, and have had a couple times when it was flashing and my car would not start. On both occasions i was able to just keep tying it and eventually it started.
I have now wired in a resistor of the correct ohmage as shown in the diagam on shoeboxes site. When i got under the dash to clip the wires needed, i noticed one was already broken off. I put the resistor in as needed.
Now i havent had any trouble with the car not wanting to start, but the security light is always on, which makes me nervous. I also had the resistor fall off once and the car continued to start no problem.
So does anyone know what the deal is here? I thought if there wasnt a resistor in place the car wouldnt start period? Has my car been messed with or something?
Old 02-20-2005 | 08:33 AM
Dave89IROC's Avatar
Re: Trouble Deleting VATS
if there is the correct resistance on a start, then it is lost during that run time, it will continue to start as a default till it is fixed, if it had the correct resistance for a entire start/run period, then lost it before the next start, it wouldn't start
Old 02-20-2005 | 08:56 AM
Valkyn71's Avatar
how do i get the serurity light to go off?
Old 02-20-2005 | 09:01 AM
Perhaps your resistor is not working or connected properly or there is some other problem.
Old 02-20-2005 | 09:14 AM
Valkyn71's Avatar
What other problems could their be?
Old 02-20-2005 | 10:11 AM
Your resistance may never be making it to the VATS module. I would check the wiring with a meter to be sure. Otherwise, the module could be bad.
Old 02-20-2005 | 10:40 AM
Valkyn71's Avatar
is there anyway to just completely disable the whole friggin thing?
Old 02-20-2005 | 03:21 PM
Dave89IROC's Avatar
program out of PCM, remove VATS module and bypass the theft relay
oh, you could leave the module, it would leave the light on though, just unplug it, then bypass the relay and get it programmed out
Jeff1904
06-05-2016 05:00 PM
Ericksd
01-20-2016 06:07 PM
colts0455
10-04-2015 09:47 PM
colts0455
09-27-2015 01:07 PM
Quick Reply: Trouble Deleting VATS
