Turn signal won't work! (not bulbs, not flasher, keeps blowing a fuse)
Old 04-18-2007 | 05:52 PM
6SpdLT1Z's Avatar
Okay, whenever I signal for a turn nothing happens.... no indicator light, no clicking, etc.
The bulbs are fine, both the DRL and hazzards work fine. I've replaced the fuse, then I replaced the flasher. Now It keeps blowing a fuse, I've went through 3 fuses and I don't know what to do.
Any other suggustions?
Old 04-18-2007 | 10:35 PM
nocturnalLT1's Avatar
It would be hard to say but it sounds like something in the circuit is shorted to ground. This might require some diagnosis with a multimeter. Has it ever been in an accident?
Old 04-19-2007 | 09:17 AM
OBE1 95Z28's Avatar
Another vote for a short in the wiring. Are the bulb sockets corroded? Was it blowing fuses prior to you replacing the flasher?
Old 04-19-2007 | 01:56 PM
6SpdLT1Z's Avatar
it randomly stopped working... I replaced the fuse and it just blew so I tried replacing the flasher and it keeps blowing a fuse.
I suck @ electronics and have no clue what a bad ground is even really nor how to fix it so I'm just going to take it to the shop, I'm sick of ****ing with it.
Old 04-19-2007 | 04:25 PM
OBE1 95Z28's Avatar
A short/open is usually caused by a pinched wire.
10-31-2016 11:09 AM
stangspank
11-13-2015 01:02 PM
squarehead
01-15-2015 07:02 PM
vinnyxgunz
08-28-2002 09:41 PM
Red97LT1
08-04-2002 08:01 PM
Quick Reply: Turn signal won't work! (not bulbs, not flasher, keeps blowing a fuse)
