Vents work but now very well
Old 08-02-2008 | 05:26 PM
mrmint69's Avatar
My dash board vent will not come right away and don't blow very hard when they do. I checked everything under the hood and it all checked out. Is there something to do in the interior of the car?
Old 08-03-2008 | 12:56 AM
Ratlor's Avatar
I had a problem similar to yours, turns out I had a small crack on my vacuum check valve for the HVAC seen here.
You may want to check that out.
Old 08-03-2008 | 08:19 PM
mrmint69's Avatar
I replaced the check valve and it appears to be working better. It will come on and start working within 30 seconds and I notice that if i change to other settings there is a air noise that you can hear that is coming from inside the dash. Must be a small leak inside the dash area. It all works but it takes time to get up to speed.
Old 08-03-2008 | 10:46 PM
It's normal to hear a vacuum hiss as the mode changes.
*Emilia*
05-13-2015 09:05 AM
CARiD
01-14-2015 04:00 AM
Catmaigne
12-25-2014 12:16 PM
Red_94Formula
Parts Wanted
12-06-2014 11:07 PM
Quick Reply: Vents work but now very well
