Voltage Issues
Old 03-17-2010 | 10:24 PM
milanr's Avatar
Unhappy Voltage Issues
Hey guys my car always had some low voltage problems but it was never this serious. The gauge show a normal reading when the engine is cold but once it warms up it drops way into the red to the point where it stalls when you're stopped at a red light. I have a brand new battery in it and a brand new alternator (150 amp). When I checked it with a meter is reads 15.5 when cold and 10.5 - 11.8 when warm. I took out my fan relay turned all the light and accessories off and it only went up a little bit but never out of the red. Anyone else have this problem? Also I was told that it could be a starter drain and when I checked the wires to the starter I noticed that the solenoid felt loose so I picked up a new starter but it didn't help. Anyone have any input for me? Thanks. Btw it's a 94 z28.
Old 03-18-2010 | 02:54 PM
97FormulaWS-6's Avatar
Check all your cables. Sounds like you have a bad connection somewhere. Check all the battery cables; Positive, negative, and alternator.
Old 03-18-2010 | 04:36 PM
n2ceptor's Avatar
Voltage should be 13.8~14.2 at the battery at normal temp and idle.... As stated, check connections, corrosion, etc...
I have seen new alts that had bad voltage regulator too....
Old 03-19-2010 | 12:14 AM
milanr's Avatar
Thanks a lot guys. I'm gonna go check the cables tomorrow and if anything bring the alternator back to the store for replacement.
10-31-2016 11:09 AM
Lt1son
05-27-2015 10:35 AM
Scottyboy
02-11-2015 10:28 PM
Gtpguy
01-26-2015 04:50 PM
pete53
12-09-2014 07:31 AM
Quick Reply: Voltage Issues
