Well i stripped a couple of header bolt holes!
Old 04-16-2008 | 06:06 PM
TeamingTealZ28's Avatar
Ugh.. sucks
everything was going great till i start putting the bolts in..
Well they are stripped, anyone know the size so I can go get a re-threader?
pissed off
Old 04-16-2008 | 06:34 PM
3/8-16
Old 04-16-2008 | 07:33 PM
Best way to go is what.........thread chaser?
Old 04-16-2008 | 09:17 PM
If they are truly stripped, a thread chaser is not going to fix it. Heli-coil or thread insert will have to be done. Whether there is room to correctly do that with the head on the car is a concern.
Old 04-16-2008 | 11:06 PM
Yep. Oh man what a PITA.
With my luck they are definitly stripped. I dont even think i can get an angle drill in there!
Great time to do a head/cam swap though. But it comes in a time of no $$ to spend.
Old 04-17-2008 | 06:11 AM
shock6906's Avatar
You must have that 1/4 turn mentality.
"It's almost tight...just needs another 1/4 turn!"
*turns the bolt*
"Dammit! I stripped it! "
Yeah, I used to be that way too...
Old 04-17-2008 | 09:22 AM
ss.slp.ls1's Avatar
Torque specs ftw.
Old 04-17-2008 | 11:30 AM
haha yea.....
Major problem was holding the header and threading in the bolts..sucks man..it sucks
im goin to sears right now to buy a thread restorer kit and see how that goes. my luck is i gott pull the heads and all
Old 04-17-2008 | 12:08 PM
Kevin Blown 95 TA's Avatar
Originally Posted by ss.slp.ls1
Torque specs ftw.
You use a torque wrench on LT1 headers?
Old 04-17-2008 | 01:23 PM
sherwinZ28's Avatar
I could never fit a torque wrench on the header bolts any which way I tried, unless the headers aren't in the way. Try that with SLP shorties, not happening.
Old 04-17-2008 | 02:03 PM
ss.slp.ls1's Avatar
Yes sir.
A couple swivel head extensions and it was good to go.
DirtyDaveW
12-01-2016 05:37 PM
maybe2fast
03-16-2015 09:45 AM
crazypurgatory
01-12-2015 10:45 PM
Joes96z
12-13-2014 07:48 PM
SavageZ28
17
07-14-2002 11:04 PM
Quick Reply: Well i stripped a couple of header bolt holes!
