What kind of oil
Re: What kind of oil
Its holds 5.5 quarts. 10w30 standard oil is what I use. I guess you can spend the extra on mobil 1 if you want. But I have also heard that using synthetic in the ls1 will make piston slap more noticeable.
On my 94 TA & 89 Iroc, the oil filler cap on both tell you to use 5W30. However you should consider weather conditions. For the winter I use 5W30 and in the summer I use 10W30, which is a little thicker.
My dads car has over 230k on it and have always ran Wal-mart bought super-tech 10w30...changed every single 3000-4000 miles.
If you are going to chage it every 3000 I am convinced that you do not need synthetic.
