will 410s last in my 10 bolt? or would 373's be the best way to go?
Old 11-15-2004 | 07:24 PM
  #16
Mike94ZLT1's Avatar
Re: will 410s last in my 10 bolt? or would 373's be the best way to go?
4.10's are for GM rear ends. I have a 9" moser in my car right now with 4.11's, which are a Ford gearset.
Old 11-15-2004 | 07:45 PM
  #17
Spinner's Avatar
Originally Posted by stereomandan
Like others have said, in the 1/4 mile, the 4.10 gears are only going to help you up to about 35 mph. From then on, the 3.42's would be slightly faster.
For driving around town, they will feel faster because the TQ is multiplied in each gear more, but you run out of gear much sooner in speed. So you have more TQ for less mph in each gear.
If I change gears, I'm only going with a 3.73, but never to the 4.10. I have a hard enough time with traction with the stock 3.42's, and that's with 275/40-17's.
Dan
Keep preaching the ignorance. Unless your running 120+mph traps, and assuming you have tires, 4.10s will be the faster gear in the 1/4 mile in an A4 or M6, because you'll stay in your powerband longer, cross the traps closer to if not in the top of the powerband, and have more mechanical advantage. Period.
Old 11-15-2004 | 09:51 PM
  #18
stereomandan's Avatar
Prove me wrong.
Did I say he would be slower in the 1/4 mile? No.
So yes, I'll keep preaching, Thank you very much. Maybe you should read a little more carefully before getting on my case.
The more you mod for top end power, and raise the redline, the more gears become important. 4.10's and 3.73's can be a big advantage then. Remember, this guy is close to stock with a stock redline.
Dan
Victor Lamb
08-26-2017 02:52 PM
BLK1997Z28
05-02-2015 01:26 PM
maybe2fast
03-16-2015 09:45 AM
ddr698
01-09-2015 10:05 AM
Quick Reply: will 410s last in my 10 bolt? or would 373's be the best way to go?
