Will the rear brake line bolt in to the master cyl?
Old 03-21-2007 | 06:36 PM
TwEaKeDSS's Avatar
I am doing the ABS conversion and I believe I read somewhere that the rear brake line that goes into the ABS unit can be bent and installed into the master cyl. But isn't the fitting different from the stock fittings that connect into the master cyl? So I would assume that I would need some sorta conversion adapter to connect it to the master cyl. Or am I wrong does it just bolt right in?
Old 03-21-2007 | 06:54 PM
chevynutman's Avatar
not sure if it will fit but most sizes are not close enough to mix up.just don't go by what size wrench you need cause thread size will change if it goes from metric to standard
Old 03-22-2007 | 05:23 AM
Your post was already moved from this forum once because it belongs on "Suspension, Chassis and Brakes". In the future, do not repost on the incorrect forum. Do not post the same subject on multiple forums.
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
Jazsun
12-29-2014 12:14 PM
Red97LT1
9
12-17-2014 06:13 PM
Quick Reply: Will the rear brake line bolt in to the master cyl?
